whats max engine set back with stock firewall ?? anyone every move theirs back . the reason i,m asking is i have a old set of DAVIS Step headers from a previous G-body ( 78 Monte ) and while mocking them up on our 81 BU the rear tubes are a wrap around the frame and after notching the bottom of the frame too clear the tube , the tube is right up tight against the lower A-arm mount and that,s with no bolts .
next ?? is it possible i,m not using the correct motor mount or position in the frame ?? and the motor is too far forward ?? the car was a roller when we got it and had no motor mounts .
