Need advice Spacer or no spacer
sean_malibu
209
Langley B.C. Canada
I'm putting a cheater nitrous plate system in my car.I have a 427 stroker Bbc,iron heads, valves are 225/188. it has a Holley strip dominator intake thats been worked a bit, 800 holley dp.Going to start with a 150 shot and work my way up.
My question is,do I need to use a spacer between the manifold and nitrous plate?If so, what size?
Thanks Sean
Excelerater
6,798
Memphis,TN
nope,you do not NEED a spacer ..........
Spacer's do sometimes add more power to a engine though
minimal at best.......watch your hood clearence too..
sean_malibu
209
Langley B.C. Canada
I probly have enough clearence but if there's no advantage then I won't bother.If I want more power i'll just use a bigger shot.LOL
Thanks for the info
Sean
toxicbu
616
romeoville il
i ran that same set up your runing now you will like the high rpms i spun my bbc 427 to 8000 , and shot a 125 at it with out any trouble enjoy
tyster89
979
North of ST Louis MO 30 miles
Adding to the ? If you were to run a spacer with a plate, is the plate above or below the spacer?
TNTS79
1,252
Illiniois
I would say run the spacer below the plate. Carb/plate/spacer/intake...
maliburon
363
Long Island, New York
I have another ? If you are running a four hole spacer with an rpm airgap should I change to an open spacer?
TNTS79
1,252
Illiniois
Only way to know is to put them on and make some passes or dyno pulls, test and tune... Generally opens spacers tend to work better with dual planes but its all dependent on what the motor wants. Only way to really know is on a dyno or making passes with a tuned combo to start with.
