need combo help
tinkertoy
41
st louis mo
my motor is in machine shop now ,its a 406 with probe ft pistons ,forged rods,and a new cast crank . the rotating assembly is balanced. heads are older dart 200 cc pro 1 alum. compression should be around 10.5/11.0 . 800 holley dp .i am thinking of running the lunati voodo 284 cam hydralic ground on small bc. what converter should i use? i have 4.11 gears with 28./11.5 ets. what est on hp .
purple barney
576
Raleigh NC
i would say close to 400hp at the flywheel maybe a little more. with that cam i would run at least a 3500 stall. is it a street car if not i would run more stall. call jw they can tell you exactly what you need.
tinkertoy
41
st louis mo
i was hoping for more in the 470/490 range . my friends motor makes @470 with less comp,and less lift on cam .he even has 993 aero head stock replacement heads with some port and bowl work.it is also a 406. not that mine will be any better than his,just thought it would at least be comperable.
Blackwizard22
453
NJ
That combo would be good for 450+ hp at the fly.
I think you would be good with a 3000 stall if it is street/strip, if its race only you could step up to a 3500.
cutlass389
684
NC
IMHO, any hydraulic cam is limited to about 6000 rpms where they go into float unless extreme measures are taken for maybe 500 more. Hp is going to limited by displacement and compression ratio when rpms are restricted.
injected
432
Quebec , Canada
X2
dev1360
561
East Alton, IL
Hydraulic lifters are spinning higher than 6k these days. And it's the lifters collapsing, not valve float. I would think that motor EASILY makes 450+ at the flexplate. I would go for at least a 3500 stall.
