need help finding a turn signal lever
Killerdave8813
904
Cincinnati,Ohio
I've not actually tried it but Bill says he tried it the other way,big stalk into a little hole won't work but if the end is the same it might fit,the only problem might be be that it needs support but then again it might go in the without an issue,I think it's woth a try,they want $70.00 for the turn signal lever or the multi function lever?
melloelky
3,654
31
mass
i've gotten a Turn Signal Lever at napa for alot cheaper than what i'm seeing here,or am i missing something?sorry in advance
fatwreck
14
gmclassic parts want $70 for the plain turn signal lever.
Napa has this one for $11 and the wiper/cruise ones for $12.50, but not the one that I think I need.
Killerdave8813
904
Cincinnati,Ohio
Nope that's not the right one,I believe the one you have a pic of from ebay is the correct one,that is for the 78 to 81 column and it does look the same on the very end as your switch lever,I've not fooled around with turn signal levers yet but am told they pop right in and out,I'd say it's a good possibillity that you get one for a 78 to 81 and it'll pop right in there,but that's only a somewhat
educated guess!! It looks like it's up to you to finish the experiment!!
fatwreck
14
I agree with what you're saying...I just need to find one that isn't $70. I figured I would try the wanted section first and then the junkyard next.
melloelky
3,654
31
mass
81regal is parting out an 80 monte,check with him to see if he's any help
shvrolay
shvrolay said:
You're right KillerDave........won't fit.
Just tried fitting a lever from an '83 G body into my '79 column - no go. Never realized they weren't the same size.
............oops - my bad!!!
Just measured the two different style shafts, and they're the same size. Tried again to fit the later style into my '79s column and after some wigglin' - it popped right in!
They are the same size..........sorry for the misinformation on my part.
