Are you sure you have the fuel lines right on the pump? and when you say new carb, is it brand new? did you check the float level while the carb was off? try taking a needle and putting gas in the carb through the site glass that way and see if that helps any. Whats the gap on your plugs? for HEI should be about .045, do you have another pump to try?
