1camaross said:
i am in the process of installing an 8 point roll cage and would like to see how you guys attached to the frame did you use the 6x6 steel square to the frame or just put the tube to the frame and how did you anchor the trunk bars thanks anything would be helpful i have searched alot and cant get and good pics
I cant find any good pics of my cage install...
As for the trunk bars, They were the only ones that I used the 6x6 plates....
Welded those plates right on top of the rear spring perch..(On the frame,,,NOT to the floor pan..)Then the trunk tubes to that....
But a cage can be done so many different ways... Guess its all in what will work best for your build... j/m 02
