pinion angle?
Hiway
3,932
Enola Arkansas
What are the nine and ten second cars using for pinion angle? All heim joints....uppers and lowers in stock mounting holes.
5-door
3,845
Cottage Grove, MN
www.jtraceshop.com
CutlassRacer said:
If it is all solid and the mounting points are reinforced all you should need is 1.5 to 2 degrees down.
Agreed. 2 degrees down should be about perfect with all solid mounting points.
If it were all poly mounts, I'd go roughly 4, maybe even 5 degrees down.
All stock rubber mounts, 7 degrees down.
BMR Sales
452
-2 to -2.5 is a good setting for heim joint components, -2.5 to -3.0 for urethane.
