Pistons that are machined for floating wrist pins can still have the wrist pins press fit to factory connecting rods. You just don't end up using the wrist pin retaining devices (spirolox, true-arcs, wire rings).
ProJunk said:Pistons that are machined for floating wrist pins can still have the wrist pins press fit to factory connecting rods. You just don't end up using the wrist pin retaining devices (spirolox, true-arcs, wire rings).
360demonRT said:how much lift can ya get out of a stock LSx spring?
dennisM said:ProJunk said:Pistons that are machined for floating wrist pins can still have the wrist pins press fit to factory connecting rods. You just don't end up using the wrist pin retaining devices (spirolox, true-arcs, wire rings).
So what else (if anything) should I buy with the piston?
