Reading Plugs in Kohler V Twin
StreetBu
4,158
3
Upstate NY
Hmmm. Electric clutch on it correct? Wonder if the bearing is is starting to fail in the PTO clutch. It's not replaceable by itself, have to replace the whole clutch. Ouch! I hope not!
StreetBu
4,158
3
Upstate NY
Wow, never seen a zero turn without an electric PTO clutch...the engine only has one set of holes it can be mounted in? Then maybe check the idler, usually they are mounted on a slotted hole in their arm to adjust belt tension when it's engaged.
4,749
The engine mounts are slotted with an adjuster at the back of the frame. I did not touch the adjuster, so the engine should be more or less where it was before. I drew circles around the washers before taking it out, and the washers seem to be in the same place as before.
This manual is close, but I am not sure it is identical to mine.
