Has anyone ever tried to use rear disc setup off of a 79 to 82 Pontiac Trans Am on a 8.5 in a G -Body? If so any mods or was ti a bolt up Program. Any input would help. THANKS
I have not tried, but have been told it bolts right up. Only problem is it's costly parts wise. If you good used stuff then go for it. The onther downside is weight if thats a concern to you. Those cast iron calipers are HEAVY. I'm probably going to go with a set from the rear of an s-10 with disc. Easy, cheap, and aluminum
