Rear question.
Kansas Bu Wagon
13
Wichita, ks
I've been reading around about rears for a little bit and when the time come's I don't know if I should try and get a 8.5 or build the 7.5.
I know everyone says junk the 7.5 but I don't know how much power they make.
I want my car to be around the low 13s, and it will be a street car maybe a weekend or to at the track.
I'm not real worried about it right now as I'm a ways away from a bigger motor, just curious.
lilbowtie
1,736
Canton Mi.
I ran a 7.5 rear w/ an auburn posi for 3 years in the low 13's before switching. When I took it out the gear lube had a lot of metal in it - the spiders were going. If your going to put any money into a 7.5 it would be better spent on something else. If you have 7.5 ready to go - run it.
Save the dough for a rear end that was designed for something a little more stout than a Vega 4 cylinder...
4,759
The standard Vega came with a 6.5-inch rear. The Cosworth Vega came with a 7.5-inch rear.
The Monza came with 7.5-inch rear starting in 1976(?). A 1975 V6 Skyhawk still had a 6.5-inch rear and small rear brakes.
Kansas Bu Wagon
13
Wichita, ks
Haha I think I'll take this advice.
I was reading about 8.5s and read that the drive shaft will need to be shortened, would this apply to a wagon?
grizwald
3,300
Ontario, Canada
http://www.maliburacing.com/forum/viewtopic.php?f=10&t=113624
here you go....bolt it in and be done! he may even have, or know where to get a driveshaft.
Kansas Bu Wagon
13
Wichita, ks
1200 is a little on the high side.
Thinking about an 8.8 swap. Found kits on baselinesuspensions.com.
Do I need the uca/lca kit?
And what is the width compared to my stock 7.5?
Anything else that would need to be done?
Thanks, Aaron!
True. Also still a 4 cylinder... :lol:
