Where is the best place to look for a complete front end kit. All bushing, rod ends, etc.. looking to do the whole front end while front clip off and engine is out. Thanks
Used to be RockAuto.com was pretty reasonable on moog suspension parts. Not sure if there is a cheaper place these days or not. I'd check them out and compare price vs local.
When I did mine a couple of years ago, got a kit from Speedway. Part # 917-3236, $159.99. Comes with ball joints, inner and outer tie rod ends, tie rod sleeves, center link and idler arm. 1 easy kit.
I'm sure those are the cheapest economy replacement parts available. That's fine depending on what your needs might be. Just know that is roughly 13.33 for each part of the 12 part kit.
We make it easy to order replacement parts for your 1978-1988 GM A-Body and G-Body. This one part number includes: inner tie rods outer tie rods tie rod sleeves center link idler arm upper ball joints lower ball joints Item Details A-Body & G-Body
If there is an option to upgrade to polyurethane boots, do it; if not get polyurethane boots separately. The PST kit I installed in the mid 90s had rubber boots and the tie rod end boots split after a very short time.
Thanks for the information. I would like to order everything I need at one time. So any info on control arm bushings? I found the rear on the Speedway site but not the front. Also couldn't find the body mounts. In another post someone mentioned to get the body mounts for a Regal due to having additional mount? Any help is greatly appreciated. Thanks everyone
