Richmond 5 speed OVERDRIVE
LIVE4RDO
678
Staten Island, NY
John, what shifter do you use? Does it fit on the same crossmember as the Muncie?
LIVE4RDO
678
Staten Island, NY
Is Tremec and T56 two different things?
TURNA
6,028
Socialist NY
tremec makes/made T5, T500, T600 and T56 as well as others
LIVE4RDO
678
Staten Island, NY
If I remember correctly from my Mustang youth, Tremec is a better/more desirable transmission. Right?
LIVE4RDO
678
Staten Island, NY
How does Tremec compare to factory T56 to TKO 5 speed (except the obvious 5 vs 6)? In quality and durability.
If I go with any of the above, I'd have to switch to hydraulic clutch, right?
TURNA
6,028
Socialist NY
On paper the T-56 is the strongest factory stock manual trans.
As well as the strongest Tremec trans.
LIVE4RDO
678
Staten Island, NY
John, can I keep my manual linkage or do I need to switch to hydraulic clutch?
TURNA
6,028
Socialist NY
With the LS1 style T-56 you can use everything you have with that adapter plate.
Just swap the trans.
You will need to modify or a different Xmember.
Oooo a manual swap thread 8)
Don't forget the driveshaft :)
The TKO500/600 is for more of a direct swap-type deal, they have the standard old-school bolt patterns (Ford, GM, Chrysler, etc.).
The T56 is rated somewhere around 450lbs/ft from GM, Viper T56s are stronger but the input shaft has to be changed I think. There is a T56 'Magnum' that came out from Tremec rated at 700lbs/ft, and is also cheaper than the 6-speed Richmond (~$2,800 on Summit's site).
Want to make things more interesting?
http://www.keislerauto.com/recent-news/the-all-new-road-a-track-6-speed.html
I may very easily be wrong, but I think the Muncie's stronger. Maybe we can say the T56 is the strongest factory OVERDRIVE transmission?
