Roller cam/lifters
bowtie81
5,008
sarnia, ontario canada
Hey Guys,
I just jumped over to a roller cam/lifters. I've gone through the settings a couple times now but it still sounds like a loose lifter, everything is tight the way it should be. Are they normally noisy? I was told to run 5w30 for the initial start up.
Am I missing something, I plan on running a ticker oil after.
Are they solid roller lifters? All solid lifters are noisier than hydraulic flat tappets. I have also heard of complaints about Morel Hydros ticking, but no reports of them failing.
bracketchev1221
1,111
Mountville Pa
If hey are the morels or lunati, or howards, look into hydraulic roller oil on the internet. Chris Straub has put multiple posts about the "right" oil to use in them.
D sbc hydraulic roller cam for a/c?????? Drivetrain Technical 15
T lunati solid roller voodoo cam Drivetrain Technical 6
JP86SS Roller Cam, old block struggles Drivetrain Technical 6
87Aero Pace Performance Stainless Roller Rockers for mild cam?? Drivetrain Technical 7
7 edelbrock removable timing cover with roller cam Drivetrain Technical 0
t5montecarlo L69 vs. Roller Cam Drivetrain Technical 4
87Aero Roller lifter/cam question Drivetrain Technical 2
ElCaminoBill Roller cam conversion Q's Drivetrain Technical 7
D Self alinging roller rockers? ? ? ? ' s Drivetrain Technical 3
D Comp Cams RETRO Hyd. SBC Roller Lifters ???'s Drivetrain Technical 3
Supe Solid Roller vs. Hydraulic Roller Camshafts Advanced Technical 8
D SBC ROLLER ROKER ARMS RATIO ???'S Drivetrain Technical 14
lightmalibu79 adjustment of roller rockers Drivetrain Technical 5
7 Noisy Roller Rockers Drivetrain Technical 4
elcaminoss84 roller rocker question Drivetrain Technical 7
B solid roller lifters mod??? Drivetrain Technical 2
S Solid Roller cams? Drivetrain Technical 8
R Guideplate vs self-aligning roller rockers Drivetrain Technical 18
R Who has the best lifters for a OEM Hyd Roller SBC Drivetrain Technical 2
Dan Aughtman SBC Hydraulic Roller Lifters? Drivetrain Technical 0
Dan Aughtman SBC Hydraulic Roller Lifters? Drivetrain Technical 2
R priming question engine with a solid roller Drivetrain Technical 2
Dan Aughtman Edelbrock Roller Cams Drivetrain Technical 0
87Aero Roller rocker alignment question....... Drivetrain Technical 5
NYCAMINO which roller rockers for vortec heads? Drivetrain Technical 5
A comp 853 high energy lifters (roller) problems? Drivetrain Technical 3
DOUG213XRJ Cam break in oil ? General Discussion 4
DOUG213XRJ ceramic coated headers and breaking in a cam ? General Discussion 1
blown 78 Need some cam help LSx Tech 1
D What cam for stock SBC 400 engine????'s Drivetrain Technical 9
prostreet66 Still stuck on cam choice Drivetrain Technical 6
D MAX CAM LIFT FOR STOCK SBC 305 ENGINE???'S Drivetrain Technical 6
D Will this cause to much cam lift ???'s Drivetrain Technical 13
prostreet66 402. Big block cam info Drivetrain Technical 2
jwelshdesign 383 heads and Cam questions Drivetrain Technical 7
J Right cam for 144 supercharger? Power Adders 20
D Off the shelf cam for ls1 shorty with ported ls6 heads? LSx Tech 2
S cam and converter help! Drivetrain Technical 2
W needing to make some changes cam? heads? carb? Drivetrain Technical 14
Jason80MC Cam Help Drivetrain Technical 4
Jason80MC Cam or not Drivetrain Technical 5
45CHI CAM swap LM7 5.3L/TH400 ??s into 86 CUTLASS COUPE LSx Tech 4
B cam question Drivetrain Technical 10
F cam bearings Drivetrain Technical 3
464elcamino picking a new cam over winter any ideas Drivetrain Technical 9
C sealed power cam and lifters Drivetrain Technical 6
M cam rpm range? Drivetrain Technical 2
StreetBu 2011 game cam pics :D Firearms/Hunting 3
vtakiaman LT1 385 stroker cam to rod clearance Drivetrain Technical 4
R what cam to use? V6 Tech 3
Similar threads
