SBC Power Steering Brakets?
Dan Aughtman
42
Andalusia, AL
I have a 1978 Malibu with 350, Air and Power Steering? Wanted to remove air but retain Power Steering. Looking for a Bracket recomendation. Tried March and Borgeson from the aftermarket, guite a joke. I will replace the 350 with a 402 Dart SHP with AFR 195's when I get a few problems ironed out. Ary help would be greatly appreciated! Thanks.
melloelky
3,654
mass
i actually modified that big a/c- p/s bracket to just hold the ps pump.i widdled it down pretty small to just attach to the front header bolt aided by a spacer and it allows full adjustment of the pump.I'm not using it anymore i switched to serpentine set up but i could take a picture if you'd like so you could see what I'm talking about.
Dan Aughtman
42
Andalusia, AL
Great, I would appreciate a pic! I have a coup;e of ideas but thought someone might have solved the problem! Thanks!
shvrolay
There is the factory bracket:
....most people forget to take this piece when removing the AC delete set-up from a donor car. Most any GM vehicle with a small block/no-AC/pwr. steering has this same bracket.
If you need/want a picture of just the bracket.......lmk.
HTH
Dan Aughtman
42
Andalusia, AL
Thanks again for the help! I will look around for a factory model, might try to fab ome.
melloelky
3,654
mass
here's mine that i used with a stud and a spacer off the front exhaust bolt.
Dan Aughtman
42
Andalusia, AL
Thanks for the help! What serp. system did you choose to use?
melloelky
3,654
mass
i went with march,w/the over driven water pump ratio
