SBC ROLLER ROKER ARMS RATIO ???'S
YAV8
155
Manitiowc, Wisconsin
The ports on a stock SBC exhaust side are not as good as the intake side. Most people just use then on the exhaust side if the cam is a SINGLE pattern. If its a DUEL pattern then use them on both sides.
prairiehotrodder
1,576
4
Melfort Saskatchewan Canada
Nobody can give you an answer if you will gain anything from playing with the rocker ratios. Its just a tuning trick to try and gain power. You do it then tell us.
Brian
bracketchev1221
1,111
Mountville Pa
Yes the small block benefitted from higher ratio on the intakes. This is not always the case and may not be as easy any more with better cam designs. Years ago with limited cam offerings, it was a bandaid for cam design. Today its not really needed.
