spraying my 388 got lotsa?????????
SS-CRAIG
321
JUST SOUTH OF ROXBORRO N.C.
okso i did a bad thing went to speed unlimited up in maryland when i was at school last week and i bought a sniper setup
heres the rundown on the car
388 hyper pistons 0 deck 10.75:1
2.02 /1.60 200 cc intake runners aluminum heads running autolite 25 plugs
performer rpm vortec style port matched
800 dp holley ROCKET SPECIAL edelbrock fuel pump mechanical 6.5-7.5 psi always
summit ignition with digital box with rev limiter
hooker supercomps 2.5 pypes with x pipe all the way out the back
super street fighter tci th350 coan 3500 stall
9 inch 3.70 gears
i want to hit it with a 100 shot to start with a w.o.t. switch.. im not too proud of the hypers
ok now the questions
what plugs do i run?
what do i do with the timing?
can i tap off the outlet of the fuel pump and be ok?
any help would be great and yes i know i cant hit it twice in one run :-"
thanks guys
craig
eldabo
1,811
Mobile,Alabama
What hp shot are you going to spray?
eldabo
1,811
Mobile,Alabama
Woops missed that .
BottleBaby Bu
859
Houston, Texas
www.Houstonhotrods.net
9 inch 3.70 gears
thanks guys
craig
Your spraying a 100 shot, dont over think it. Run the same plug you run on motor. Pull a degree or 2 if you feel like it. Yes, you can tap in the fuel with a T.
DL
49
AURORA MO
what cams in it , whats times does it run n/a
Bigblockguy
195
ste Anne mb Canada
On such a small shot you don't need to worry about much. It's not recomended to run a mech fuel pump with spray but with a 100 shot you should be ok. I would run a fuel pressure regulator for the nitrous side .
