swapping from bench to bucket seats
Killerdave8813
904
Cincinnati,Ohio
jabo said:
So i can use the mounting points where the bench seat already bolts & just make mounting points by the tunnel for both sides?
That would be correct,as has been stated the best thing to do is find a donor G-body with buckets and remove the tunnel mounts the outers by the doors are identicle,bench or bucket,KillerDave
DOUG213XRJ
4,671
West, MI
I Think you could also use another pair of bench seat mounting stands, That would make your search much easier. Ive see bucket seats installed with a block of wood so the seats set level, Then drill a hole down though the floor . Use a nut and bolt and a few large washers. With the seat track cover screwed on I couldnt see the block of wood. Doug
