T-5 with Ford bolt pattern for sbc
turboapache
69
LAKE PLACID FLORIDA
does anyone know how to install a would class T-5 with a Ford bolt pattern on a early 350 chevy. I was told that it is a chevy T-5 trans. I have 2 hyd late bellhousings but they have the std chevy pattern. Did 1993 and up camaro v6 s use the Ford pattern?
I don't know about the F-Body transmissions, but I went through the same thing you did. Picked up a T5 I was told was from an F-Body (WC, had the roller countergear bearing & everything). I looked up the tag (about 3/4"x5") #, turns out it was out of a '91 S10 with a 4-cylinder. I don't know where the trans. mount will be in relation to the stock one (an F-Body T5 will fit with minor work to the stock crossmember pad), but to bolt it up to the engine you'll need an adapter bellhousing, which will likely be $350 or more.
turboapache
69
LAKE PLACID FLORIDA
I solved the problem. I found a new Chevy main case for $85 and paid a trans shop to swap the internals for $100. The Camaro from 93-95 used this Ford case for some crazy reason. The first gear ratio is 3.75 in these trans just so you know.
4,759
That T5 is for a V6 Camaro. It is not rated at a torque high enough to be abused, but it will survive just fine otherwise.
The 2.95 first gear WC T5 had a torque rating of about 300 lb.ft. The 3.75 version would be rated at about 260 lb.ft. Within the same types of transmissions (e.g., WC T5 vs. WC T5), the torque rating is typically inversely proportional to the first gear ratio.
