Timing Problem
uestraven
27
Long Island
I have a 79 Malibu with a mild 350 in it. For some reason when I take a timing light to it and try to set the timing, it wont idle. I tried setting it at 36 degrees total and when it goes back to idle it just dies. Vacuum hooked up or unhooked it does the same thing. Ive tried tuning the carb differently, changing the air mixture screws and idle air bleeds, i even rebuilt the carb. All the plugs and on tight and ive checked to make sure all the timing marks line up with tdc. But I still cant get it to idle until 25 degrees initial timing. Please help!
bracketchev1221
1,111
Mountville Pa
Did the balancer ring spin?
uestraven
27
Long Island
The balancer ring couldn't have spun BC it still lines up at tdc
4,665
32
sounds like the balancer and the timing mark are not a matched set. You can index the balancer against your timing mark using a piston stop and degree wheel. You can print a degree wheel from various places on the internet.
SSedan64
948
MACON, GA.
That's what I was thinking t5monte but, he said the timimg marks are aligned @TDC.
uestraven, are you sure you don't have a bad Vac leak?
Does the Vac Advance have any effect when connected/disconnected?
uestraven
27
Long Island
I thought I had a vacuum leak because I kept hearing a hissing sound but I literally doused the motor in ether and the rpms never flinched
