I have a 78 malibu with a 383 forge steel setup not sure of the cam specs but it's 11.2 to 1 compression with trick flow 64cnc heads 195 runners full roller setup. I had a th350 trans in it with a 9inch rear 410 gears and a 275/6015 et street tires. My trans just blew I was weighting my opinions on which setup to go with. I have a full built pro street th400 with a trans brake already in my garage, I was wondering if anyone had any luck with the 4 speed transmissions? The car has seen a lot of track and I beat on it pretty go but I also street cruise having the extra gear would be great! I have a nitroious setup ready to go so it would need to handle some power.. Any suggestions?
