transmission leak?
79ChevyBu
53
It is coming out of were the the speedometer cable goes into. I believe there is just an "o" ring which will be easy to change. I just wanted to know if there are any tricks or anything I should look out for.
Thanks
HP JUNKEY
1,093
Buffalo.NY
Take it out and check the "housing" for any burs, Clean, clean, clean with some laquer thinner, replace O-ring and put a light coating of RTV {black} on the O-ring area. Make sure you don't roll the O-ring out of the groove putting it back in. Mine leaked in the same spot after a $750 rebuild. Wasn't going to pull it and take it back, so I sealed it up myself. Good luck.
79ChevyBu
53
Thanks and as far as the gear thats in there will it just pull right out and go back in, no prolems hopefully.
HP JUNKEY
1,093
Buffalo.NY
It should stay put when you pull it out of the transmission tail shaft, it only slides in the removable piece with the O-ring,{not sure what the technical name is for it}, It should slide back into the transmission by hand, DON'T use a hammer :!: Just some additional info for you if you need it..... That plastic gear meshes with output shaft, so the speedo will work. You can switch to a different color gear to get your speedo more accurate if it is reading too slow or fast. A local transmission shop could help you figure out which color to use, they usually just need the rear gear ratio.
Good luck!!!
4,770
39
There is also a lip seal around the gear shaft. The lip seal can be bad and the plastic gear tends to get a groove cut into it over time, reducing the effectiveness of the seal.
If you see a groove in the gear, replace it and the lip seal.
