Trunk Mount Battery ???
10secBu
4,284
Westminster, MD
GBodyFreak said:
Please do not follow that wiring schematic, nor the cable sizing. I did 15 years ago and it's not up to current race car wiring contruction standards.
10secBu
4,284
Westminster, MD
http://www.maliburacing.com/forum/viewtopic.php?f=14&t=67979
BTW, your battery mount kit is the cheapest part of relocating the battery in the trunk. The rewire shown in the above link, the parts alone cost $500 for the wire, lug terminals, heat shrink, fuse & fuse holders and cut-off switch.
All the wiring with my car is inside the car as with any production vehicle. This protects the wiring from anything on the road/track that could potentially damage the wires or cause premature corrosion of the wire/connections.
GBodyFreak said:
That diagram isn't right nor is it safe. The power switch must disconnect the battery & the alternator from everything, not just disconnect the battery from the accessories.
Goob
3,641
Indianapolis
gn clone said:
Why not just put the switch on the ground wire?
Too many case grounded devices to isolate for a ground side switch.
I didn't study that diagram too close, but for a car to be track legal, the alternator must be isolated from the switched power, so the engine will shut off, even with the alternator charging, as it is shown.
