V6 PROBLEMS
i have a 1985 with a v6 just change the carb. but a having problem starts nice and everything but when i put it in drive and starts takeing off the engine whants to turn off it only does it on the take off. any sugestions. :roll: ](*,) :-k
matty man
1,353
25
Grove City , Ohio
idle set to low, timing, vac leak, vac line on the wrong port for the distributor, did you put on a rebuilt carb? Might be a accelerator pump issue as well,, matty man 8)
yea i just intalled a rebuilt carb. it
wasent doing it with the old carb. you think that this might a bad carb.
matty man
1,353
25
Grove City , Ohio
If everything checks out, timing, vac lines ect,,, then sounds like a bad carb, if you got it at a parts store check with them on how to do the exchange, should not be a problem,, but check every thing, base gasket, lines, good fuel pressure? If all cks, get another carb,, let us know it turns out,, matty man 8)
80ECLT
3,927
Sheboygan Falls, Wisconsin
guessing you mean 231 3.8 v6 cause 85 4.3 would be tbi.
