malicad
1,383
South Milwaukee, WI
FINALLY fired up the wagon after about a month being apart. Not much time these days. Ran good. Set timing to 10* to get a little more out of her. Distributor looks to be rotated quite a bit, so I think she's a tooth off. Either tomorrow or the weekend, going to loosen up the clamp and move it over after confirming tdc on #1 compression. Again. UGH
Firetruck1
1,104
Ocala Florida
I installed the Aeromotive Stealth pump in my new gas tank, ordered all the fittings and lines for the new fuel system and welded shut the old lines on the sender unit to use it as a gauge only.
78elk
1,294
81
Mountain Home Id
I adjusted the choke today. I then checked the wot from cab compared to at the carb. I adjusted so they are the same. I had to break the sleeve due to it making it stick at wot.
malibuguy
3,775
Finksburg, Md
Someone came out to look at the stocker today. Thats about it
TURNA
6,028
Socialist NY
Stood out in the yard and stared at the Monte wondering if it is worth fixing............. ](*,)
Checked for signs of mousies. All clear...
