elcaminoss84
336
Oklahoma
The one piece oil pan gasket is one of the of best gaskets over 3 or 4 piece ones for sbcs. I never had any leaks using them on my motors.
malibuguy
3,775
Finksburg, Md
Drove the stocker for the last time. Turned the tags in and posted it for sale.
And the other car I havent really touched it in weeks
TURNA
6,028
Socialist NY
68mm and 78mm twin turbos!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Also ditched the LS rear bumper and put on an SS one
melloelky
3,654
mass
78elk said:
I removed the fan and shroud, getting ready to pull the harmonic balancer. Trying to figure if I can slow the leak down.
i had to change my timing cover/balancer seal a while back.i've read about oil creeping past the seal onto the shaft and ultimately onto the outside of the balancer.before i reinstalled the balancer i put a dab of rtv on the key way portion as cheap insurance.
78elk
1,294
81
Mountain Home Id
Thanks, I'll give that a try. I pulled the harmonic balancer today. It has 2 grooves in it. I decided to get a new one. It'll be here tomorrow.
malicad
1,383
South Milwaukee, WI
Worked on the wagon a bit yesterday. Got the new spark plugs installed, removed the distributor (I think it's one tooth off), started to make my custom spark plug wires. I had the distributor out on my workbench, and because of a lack of a gasket on the distributor shaft, there was a thick oily sludge buildup all around the base of it. UGH. Took me a while to clean the distributor itself, and I had to remove the ignition module and clean that up as well. A quick search online and I found some heat sink paste available at Autozone. Three bucks and a half can each of brake parts cleaner and WD-40 and the distributor looks new again. Unfortunately, the replacement cap/rotor I bought a while back from Rockauto isn't the right type, even though I looked it up from the donor car's specs. My HEI cap is bolted down, and the one I bought has those L-shaped spring loaded tabs. A quick trip to Oreilley's and I walked away with the correct style, with brass contacts. This one is grey, so I scuffed it up and shot it with semi-gloss black. Looks nice!
