what gauge of wire.....
Goob
3,641
Indianapolis
It would always be "best" to have a full length ground cable to the engine, I am sliding by with a stud welded to the frame, and two more of them at the front, welded to the frame for a short cable to the engine, and the grounds for the wiring harness and accessories. The strap from engine or the ground post to body is essential as well.
If you have doubts about the ground through the alternator mount, a strap or wire from it to the block or other ground point won't hurt.
There are two sides to every DC circuit, and each is equally important. If there is resistance on the ground side, the alternator can overcharge, heat up, and have poor reliability, or the battery won't get charged, or your accessories and ignition could be subjected to low voltage conditions.
grizwald
3,300
Ontario, Canada
my engine is grounded from the front of the block to the frame using an apporx. 3/4"-1" wide ground strap. the battery is grounded in the back to the frame. in my mind, i've got a good enough ground, but what do you think?
Goob
3,641
Indianapolis
Well, the ground cable for the engine/starter needs to be equal to or better than the positive cable and connections.
