what power level requires drag radials/slicks
79 surfwagon
335
Texas
at what power level or ET does the car require drag radials or slicks to be consistent. Right now I'm running ground pounding 17.70's \:D/ , so my regular street tires are working fine and not spinning but maybe a fraction on launch. When will i need to get an extra set of wheels with slicks or DRs to keep consistent?
My Dad has a caballero and today was his first time at the track. This car is STACKED with a 406, ported heads, solid roller, 3.73, 3k stall, adjustable upper control arms... he did no burnout with his BFG 225/60 R15. He spun all the way through the 1/8th mile and finally got traction to run a 16.10 at 102mph.
The caballero obviously needs something better than a street tire. Do you guys know about what power level or ET estimate it starts becoming crucial to bring an extra set of tires to the track for consistent launches?
Thanks in advance
DOUG213XRJ
4,671
West, MI
Drag radials/slicks will lower the ET of any car no matter if its a 9 second car or a 20 second car.
79 surfwagon
335
Texas
okay. I'll get a set to bolt on and we'll make it an experiment. I'll need them for sure eventually, right? 8)
knievel
270
Hillsdale , MI
This is FALSE
The only way a drag radial is going to help a car that doesn't spin is by putting a different size on that helps change the gear ratio....
Slicks could actually slow a car down due to greater rolling resistance
malibulvr
1,929
Pensacola, Fl. 32526
knievel said:
This is FALSE
X2!!!!
