what would you recommend for a clutch and flywheel?
RatMalibu
2,225
Rolla, Mo.
www.fidnet.com
ahh yes then get used to the expensive clutches lol....I'm running a Weir bellhousing, normal $170 flywheel and normal $270 CF DF clutch
just looked....wow flywheels have gone up in the last few years $220 now, I paid $169
That's one reason I thought it would be better off going with the adapter bellhousing, a regular 26-spline clutch isn't as expensive as the LT1-specific clutch.
SEVNT 9
838
chicago illinois northsider
what about the center force II ???? good?? bad?? stay away from??? im not making serious hp so im guessing i could get away with it says holds 60% more than stock and the dual friction holds 90% more than stock??? what do you think???
i wonder whats so special about the LT1?????
yeah doober i hear yea
RatMalibu
2,225
Rolla, Mo.
www.fidnet.com
the LT1 uses a reverse pull off clutch...mechanically it works the opposite of a normal clutch
normal clutch
a LT1 has the slave mounted behind the clutch and pushes forward to pull the pressure plate off to release the clutch....they changed back to the normal style clutch and a hydraulic throwout for the LS1
SEVNT 9
838
good info there doober thanks!!!
bu min v8 said:
just priced one out from jegs $619.00 :shock: yikes wonder if i can find i cheaper somewhere else... ls6 tommy what would you recommend using with a hydraulic set up? keeping in mind im budget based. thanks - Shawn
Shafi uses Borg & Beck/SACHS stuff a lot. If you contact him he'll be able to point you in the right direction.
Keisler Engineering
2250 Stock Creek Blvd.
Rockford, Tennessee 37853 USA
Phone: (865) 609-8187
Toll Free: 888-609-0094
Fax: (865) 609-8287
Hours of Operation
Monday–Thursday: 8:00 am to 6:30 pm (EST)
Friday: 8:00 am to 5:00 pm (EST)
Saturday: 9:00 am to 2:00 pm (EST) call 865.414.1709 (Sat only)
[email protected]
I'm thinking of going with something from SPEC. They have really nice stuff & I hear nothing but good things. They ARE a bit more pricey.
http://specclutch.com/
