Wiseman79's LS1 build
wiseman79
2,565
Central Virginia
www.performancetech.net
Re:
basketcase said:
388bu said:
wiseman79 said:
Carb, will be using the RPM intake with the Edelbrock (MSD) controller.
What?! Dont be skerred! Do EFI! :p
I don't understand why everyone takes technology (Gen III/IV engines) and back-dates them with a carb!
I don't know a way to run my 200-4r with a factory fi setup. These engines carb'd are still a big step up from a carb'd gen I motor.
Subscribed :)
X2 on what Craig said, it'd be a pretty easy swap runnin' the 2004R.
455_82malibu
1,400
WISCONSIN
youll just need to rig up a throttle "TV", which controls the shift, and then wire up a switch for the lock-up converter, if you have one. other then the lock-up, there are no electronics needed for the r4
or for a few $ you can get a Constant Pressure Valve Body.
wiseman79
2,565
Central Virginia
I'll google the constant pressure valve, I'm not really familiar with that. My thought process that led me to my decision is based on the need for the following...
1: A custum lenth TV cable (do these exist?)
2: Bracketry for the throttle body to actuate the TV cable (This could be fabbed, but would require careful attention to the travel characteristics that the cable should experience with a carb and translating those to the fabbed brackets)
So, those two things dissuaded me from FI. If anyone has any solutions, or thinks of another hurdle that I'm forgetting, please share :-k
MalibuRacing
3,465
www.maliburacing.com
I'm not sure if they are all the same, but on my TB, there is a stud for the cruise control (I'm guessing). You could connect here. The geometry may not be correct, but you could tack weld an extension if necessary to correct that. My truck intake also has a bracket with a slot for an additional cable. See below:
Here's the correct geometry for the TV cable connection:
455_82malibu
1,400
WISCONSIN
what he said^^^ My TB has 2 studs, and plenty of metal to drill another stud if you need a little more adjustment for the cable.
I wouldnt let a cable change my mind.... FI with a 200r4 would be a smooth ride and very good on gas.
