i get people all the time at cruise inns asking if mines injected when the see the coil packs...lol
Yeah, I'm running it with a 2400rpm convertor, 200r4 and 3.08 rear so should be about right. This car is a cruiser mainly but hopefully I didn't go too tame. Stock I think is .500" so it's at least decent step up from there. I plan on driving the car 4.5 hours to Carlisle PA for shows a couple times a year and doing alot of cruising on weekends so didn't want to go too radical.Roller406Bu said:wow that's tame for a lsx camshaft...plenty of off -the- shelf proven cams out there , hope it works for you...
wiseman79 said:Yeah, I'm running it with a 2400rpm convertor, 200r4 and 3.08 rear so should be about right. This car is a cruiser mainly but hopefully I didn't go too tame. Stock I think is .500" so it's at least decent step up from there. I plan on driving the car 4.5 hours to Carlisle PA for shows a couple times a year and doing alot of cruising on weekends so didn't want to go too radical.Roller406Bu said:wow that's tame for a lsx camshaft...plenty of off -the- shelf proven cams out there , hope it works for you...
Yeah I agree on the gearing, the car has a 3.08 currently so that'll be my starting point. How quickly I swap to a lower gear will be decided once I drive it and see how it runs. The swap will probably be motivated more from the tired posi unit than the ratio to be honest.Roller406Bu said:wiseman79 said:Yeah, I'm running it with a 2400rpm convertor, 200r4 and 3.08 rear so should be about right. This car is a cruiser mainly but hopefully I didn't go too tame. Stock I think is .500" so it's at least decent step up from there. I plan on driving the car 4.5 hours to Carlisle PA for shows a couple times a year and doing alot of cruising on weekends so didn't want to go too radical.Roller406Bu said:wow that's tame for a lsx camshaft...plenty of off -the- shelf proven cams out there , hope it works for you...
Cool didnt know for sure what your plans were, I would gear it more for sure though 3.42-3.73...With that overdrive if would be perfect....
