1LE brakes
gmachinz said:
That and the distance between the cross shaft bolts are 7.25" for a B-body vs. G-body's 6.5" distance-too much fabbing-not worth it. Buy good aftermarket uppers. -Jabin
Good point. I missed that one.
ouch
:( Well, there goes that. At this point, I can't justify that expense. As I stated in the original question, it seems someone did this years ago with stock parts. Since Car Craft, PHR, and other magazines were hot for these cars way back, I can't recall who did it, and the facts have grown vague. Thanks for the help.
DeltaT
1,050
Nor Cal
I have a pair of assembled B-body spindle/1LE Rotor/Caliper/Carbon Metallic Pads/Dustshields, in good condition I'll sell for $300 plus shipping. They have a long service life left in them. Then all you need is the aftermarket upper A-arms (which I sometimes see on E-Bay) and a set of braided brake lines. They are off my 81 Bu from before I upgraded to Global West spindles/13" Wilwood brakes. The 1LE rotors are 5 on 4 3/4" stud spacing.
They weigh like 53lbs. per side, box for shipping.
PM if interested. I could post or send pix.
Jim
gmachinz
511
Iowa
Yeah, shipped those suckers are heavy! I just sent a freshly built and powdercoated 1LE conversion kit to a customer in the Netherlands and it was pricey! I sent it USPS so it still saved him considerable money over FedEx or UPS. Rotors went in each box with dust shields, calipers in another, spindles in yet another box and then all mounting hardware, pads, braided hoses and bearings/seals in another. -Jabin
malibuplotter
1,251
layton utah
388bu said:
I think a few of us know. :)
http://gparts.freeyellow.com
never seen that one before, how long has this fellow been around? anyone have his control arms? i'm all for supporting the little guy. (if i can trust his parts).
Warren/Tommy, Will the the 92 Camaro calipers and rotors work with this combo. Or YOU must use 1981 Camaro. Tommy what part numbers are your rotors/calipers from?
gmachinz
511
Iowa
You must use 1LE rotors if you want to retain the bolt pattern. 92 Camaro calipers won't fit because they use a smaller brake pad-D154 vs. D52. You can use 70-81 Camaro calipers (1/16" wider than the Caprice w/12" brakes)for the job, too. I opted to retain the 5 on 5 bolt pattern so I used regular Caprice calipers. I think the part numbers Warren used is for A-1 Cardone reman. stuff. The OEM calipers for the 1LE swap are PBR dual piston aluminum and can be adapted fairly easy to our G-bodies but the brackets for the spindle are dis-continued now. You can buy the complete loaded kit through Autozone (P4747 I think) but what good is it without the right brackets? -Jabin
Lemme reprint this from the previous page.:
Here ya go:
Spindles and calipers are from 78-90 full size Caprice, Caddy, Delta 88, and Pontiac. Typically wagon, police or with HD towing package.
Brake calipers, (1)#18-4021, (1)#18-4020
Brake flex hoses, #BH36848
Brake caliper hose bolts, #483-205
Brake pads, # D52
Brake rotors, 1LE, #5994
Wheel bearings, 1LE inner, #BR6
Wheel bearings, 1LE outer, #BR3
Bearing seals, 1LE, #19753
Hub grease caps, 1LE, #13977
If you're tearing down the steering too, here's the part #s:
Tie rod, inner, 78 Malibu, #ES2034L
Tie rod, outer, 78 Malibu, #ES2033R
Centerlink, 78 Malibu, #DS909
Idler arm, 78 Malibu, #FA1013
Ball joint, lower, 78 Malibu, #FA3000
The tubular upper A-arms required should have ball joints already installed.
79Elky
139
SW Connecticut
members.dandy.net
Dunno just how long Robert Adams has been doing his G-parts business, but he's a frequent player on Ray Buck's Elky reflector. He's a good guy and very knowledgeable. I haven't bought much from him but what I have, arrived soon enough with no problems. He's up-front and will tell you exactly what his stock and shipping times are.
Has anybody experienced,after the conversion, at top end when the car is slowing down it starts to sway and waunder ? I also installed the Trick Springs.
