79' malibu project thread
r_d_3
125
67
28
28
New Jersey
Very nice work on the adapter plate. Why is there a downward angle towards the front of the car?
Also, nice work in the panel recovering job. What material did you use? Are you going to add the strap to the upper door panel?
I don't think I'm gonna add the strap, but maybe, the material is upholstery vinyl from Joanne's fabric . and the angle is because the fire wall is leaned back some so its to makes the master sit more level
r_d_3
125
67
28
28
New Jersey
Got a little bit of work done over the holidays.
r_d_3
125
67
28
28
New Jersey
Had a snow day yesterday and got the body off and the frame out from under the car, been a while since I've been able to make any progress on the car.
  • Like
Reactions: melloelky
shoedoos
156
12
18
If you box the side rails make sure you leave a decent sized window in the boxing so you can get your fingers in there to replace/install the body cushions
  • Like
Reactions: r_d_3
r_d_3
125
67
28
28
New Jersey
Got some work done over the weekend gotta make clearance holes to fit my lower body bushings in past the frame box still. also gonna add some bracing from the coil over bar to the torque box area. still got a lot of work left to do.
