You may need to use the wiring harness from the GP dash if you also plan on using the GP gauges. However, if you're able to come by a GP wiring diagram, that might help you retrofit the dash and gauges using the Malibu harness..
Unless of course you plan to use aftermarket gauges. Then you pretty much have to fashion your own wiring harness for the gauges.
I plan on using a GP dash with aftermarket gauges.
Good luck!
