A few LSX udates
pmgm
144
OH
Saw your video the monte sounds and looks good....
littlefranks
543
pembrokepines FLORIDA
very clean install
Kevin Williams
139
Autryville,NC
www.angelfire.com
I'm not sure. My hood has a 2 inch cowl.
B.G.
171
Seymour, Wisconsin
labelblack68 said:
do you think with a smaller air cleaner it would fit under a stock hood?
If you run the factory truck brackets you may get boned by the alternator-Make sure you get the front of the engine as low as possible with your oil pan and headers on it. Pretty easy to make your own bracket to get the alt. to sit down a bit more if you have clearance issues. my 2 cents
BAD78BU
63
Texas
Did you have any issues with the pwr steering pulley hitting the ps box
79malibu
418
PA/south jersey
I read in another post that he changed it to a smaller pulley from another car
Kevin Williams
139
Autryville,NC
www.angelfire.com
Ps pump pulley is off a mid 90s gm car, that came with a 3.1 v6. I got a brand new pulley from advance auto parts. It was $15. You will have to press the pulley on further than stock. The dayco belt number is 5060905 or 6pk2300. If you need any more info just let know.
