adj lower arm question
LSJM1
134
Atlanta
I want to run LCA's that are .750 longer than stock.I bought some UMI single adj from summit thinking I could adjust them out only to find out they would be at the end of the threads
I returned them now I'm thinking some ice man double adj Do you think they have enough threds to go +.750 longer than stock
I'm on a budget can't go with the more expensive
UMI Performance
233
Bigler, Pa
www.umiperformance.com
Hello,
The single adjustable LCA's only have 1/2" of adjustment. For that much length you would need to go double adjustable like below, the Roto-Joint one will have even more adjustment than the rod end set up but both would work.
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_60_70&products_id=87
http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_60_70&products_id=379
We also have them on sale right now as well, Summit has them on sale as well.
If I can help anymore please ask. Thank you!
Ryan
LSJM1
134
Atlanta
I don't need sway bar holes so I guess I could use f-body arms how about the 2018 urethane bushings adj in the middle can that be adj. to .750 longer than stock
UMI Performance
233
Bigler, Pa
Yes #2018 control arms would work just fine and has the adjustment you need. Item #2013 and #2039 for the F-Body would also work since you don't need the sway bar holes, they also feature the adjustment you are looking for.
If I can help anymore please ask. Thanks!
Ryan
