Setting up a rear with dbl adj control arms??? any help
PONTIACMAN3
459
Manville, NJ
Does anyone know the true way to setup a rear with double adj control arms, where to start????? are the front spindles even when measuring wheel base, my rear with stock size arms seems to be off to one side??? if I even it in the wheel wells from left and right to fit the big tires will this hurt anything, then set the pinion angle once this is done?? Im starting to get very confused, every measurement seems a little different, the car ran good and did not pull but I just want to set the pinion angle proper and now with notching the frame I want the big tires to fit even on both sides!!!!! ANY THOUGHTS, THANKS ALL!!!!!!!!!
Supe
15,116
Charlotte, NC
Don't get too frustrated over it.
I've tried this more ways than I'd care to go over in detail. Easiest way I find is to adjust your LCA's first if you have larger tires, and get them where you want front to back (upper control arms connected at this point). Then, use the UCA's to center your tires side to side. Usually, you'll leave one arm alone, and as you lengthen and shorten the other, it will move the rear left or right. It's easy on a four post lift, but if you're on the ground on your back, I just spread my arms and use my fingertips to get me in the ballpark, then measure when I think I've got it right.
Once that's done, take a look at the pinion angle. If your rear is a bit off to one side, or control arm mounts aren't dead nuts on, you may have to move one upper control arm in or out more than the other to get the pinion set properly while maintaining your frame rail clearance (we're not talking much here, one or two threads can move the rear a LOT). If its looking like you will have to bring your upper control arms way in to get the correct pinion angle, the lowers may have to be extended some as well, since the tires will start to creep forward.
The hardest part is finding a reference mark to check for square. I've done it from ball joints, best measurement frame centerline set with a laser, etc, and never had any real way of knowing if one was 100% centered. Going from both ball joints and centerline, I've had my diagonals right on the money and off as much as 1/2" difference, and it made zero difference in the way the car launched or tracked for me, so I don't even double check it any more as long as my tire clearance is good and my LCA's are even using factory mounting points and a Currie rear (which I know for a fact the brackets are off slightly.)
If all four links are connected, it probably only takes me 10-15 minutes at this point to get the rear centered and pinion angle set, starting from scratch. You get used to it after the first few times.
slimbo
4,223
www.yellowbullet.com
heres how i would do it.....
make the lowers stock length. if you want the tires moved in 1/2 or back 1/2 do it equally. make them the same length.
then attach 1 upper control arm. adjust it to get the rear centered left to right. now attach the second upper (the bolt should slide right in if its at the right length. then use both upper arms to adjust pinion angle.
purple barney
576
Raleigh NC
I had the same problem a while back. I did the kind of what slimbo was talking about I kept the stock upper and lower control arms and just replaced one at a time with the new double adjustables. the problem I found is that even when you do that once you remove one control arm the rear end will move either side to side or up and down thowing off the length of the adjustable contol arm. I then tried the method that supe is talking about and made two fixed points for reference then squared everything up. that got me close but i still had to adjust each one different from the other. Once it is centered the important thing is to move both upper control arms the same to change you pinion angle and not affect your tire spacing.
