bleeding brakes/combination valve
jbaker
82
kewanee,il
83 monte with your typical combination or proportioning valve.
ready to bleed brakes, more specifically the rears only. i have heard stories about the need to move the little plunger tip, one way or the other, on the combi valve. before and during the bleeding process. any and all input is welcome.
thanks jerome
lurchsmalibu
3,774
Lakeland, Florida
Did you figure it out yet? I'm surprised nobody commented.
jbaker
82
kewanee,il
goterdone,
depressing plunger is required only, if you are pressure bleeding.
as a matter of fact there is a special tool available to hold the plunger in.
i gravity vaccum/bled mine, there fore i did not mess with plunger tip.
eveything worked fine and im back on the road
