after doing some reading, i started realizing that i possibly hookep up my brake wrong last year...look at the pic.. i have front brakes runnin off rear port and back brakes off front....i did it wrong right????
79wagonator said:Probably not. On my stock Bu the back resevoir goes to the smaller line which goes to the front discs and the front goes to a larger line for the rear drums. The older cast iron GM MCs had the large resevoir in the rear which always fed the front discs IIRC. Then again you have a manual setup so :-k
Dave 8)
Sorry I m wrong on the MC apparently there were a few variations I just remember from my 80Z28 and 74 malibu that the resevoirs were large in rear for front brakes and small in front for rear brakes like 69 camaro pic belowLS6 Tommy said:79wagonator said:Probably not. On my stock Bu the back resevoir goes to the smaller line which goes to the front discs and the front goes to a larger line for the rear drums. The older cast iron GM MCs had the large resevoir in the rear which always fed the front discs IIRC. Then again you have a manual setup so :-k
Dave 8)
I have the Master Power Brakes 1 1/8" power brakes master cylinder for disc/disc that's the older style like you mentioned. They told me to just reverse the lines when I install it. I don;t know if this would be wrong for disc/drum.
79wagonator said:Sorry I m wrong on the MC apparently there were a few variations I just remember from my 80Z28 and 74 malibu that the resevoirs were large in rear for front brakes and small in front for rear brakes like 69 camaro pic belowLS6 Tommy said:79wagonator said:Probably not. On my stock Bu the back resevoir goes to the smaller line which goes to the front discs and the front goes to a larger line for the rear drums. The older cast iron GM MCs had the large resevoir in the rear which always fed the front discs IIRC. Then again you have a manual setup so :-k
Dave 8)
from lookin @ other pics the older vettes had cast MCs w/same size resevoirs front and rear. and some other GMs had the larger resevoir in the front :? (I think trucks)
Id go by whatever the manufacturer says.
OOPs!
dave 8)
