Hitman is right about the alky myths. I have been running it since 99. I run a BLP carb and belt pump. Also stay away from cheap alky. I went to VP alky and Klotz Uplon top lube. They are the shiznit. No drainnig of the system through out the year. I just drain the fuel at the end of the year and clean the carb. Heck everyone should rebuild their carb at season end imo. I don't know about the more consistent thing but it did make my door car more predictable. It adds some down low to mid range but don't be looking for .50 or something. Also alky does absorb water easier so leave your drums sealed, and your fuel jugs tight, I even sit my stuff up on wood so it's off the ground. If your carb is setup right it will not milk your oil to the point of changing it every race. Alky motors need heat in the oil, get a temp gauge and you will be shocked that even though you water is up to temp your oil is far from it. I have benn experimenting with oil temps and my car is affected by them. You need to get your whole driveline good and heat soaked before you make time trials to have a chance in bracket racing. Last you need to put a hose off the intake or vacum soure with a vale so you can aid in your warm up by leanning the motor out with a vac. leak. With the price of leaded race fuel I will be on alky for awhile. Stay away from E-85 right now since there are consistantcy issues with the mixture of ethanol.
