Frame patch panels?
brrymnvette
316
St Louis, MO
Does anyone make patch panels for the frame? My body mount hole under the pass front corner is gone. I need to repair the section and didn't know if anyone made a panel for it? I was just going to weld in an oversized washer.
gstock8732
756
Jersey
http://www.gbodyparts.com/product_info.php?products_id=619&osCsid=a775a3d10a8517ac0af1f8eca8965bca
brrymnvette
316
St Louis, MO
Thanks, but I don't think that's big enough. Looks to be just about where the rot on mine ends. The entire bushing will easily slide right through on mine.
When I did my chevelle, I used a hole saw to cut a piece of steel large enough, then after I welded it in, I drilled the hole for the bolt.
