Front tires hitting inner fender on outside
The 2025 Calendars are HERE. Two different editions, two different sizes, and a digital package!! Starting at $12.97US
Jeff.Mc.KC
113
Pump Gas Small BlockVille USA
2 inch drop spindles and moroso springs dropped front to right where I want, 1/2 inch from the rubber bumpers on lower a-arm, but tires hit the inner fender on the outside edge now. I really dont want to raise it has anyone came up with a way to do away with the fende support where it rounds off to meet the fender so you can roll the edge? I know I can cut and make a new inner fender this is not what I am looking for I woul like to have a stock look when done. Thanx
John N
3,108
South Jersey
jackstandracing.com
I ended up putting 1" spacers in after I wore holes through the plastic inner wells. You could notch out the plastic inner fender wells though. On the malibus they are metal behind and they should still be more than strong enough.
