Front Trick Help!
DopeSick78
New Member
Feb 29, 2020
4
4
3
50
Hello everyone! I did not see a thread already addressing this so I hope I'm not re creating the wheel here. I have a 78 Malibu with a LS swap. I need to replace the front springs, this is going to be a grudge car so I am looking at the Moroso 47130. I would like to have the ride height about 1.5 inches lower than stock. Can anyone recommend how much if any to cut coil wise, or if there is another manufacturer option im open. I just don't want to have to run the 35's off my truck on the front :)
Thanks in advance for the help.
r_d_3
24
24
New Jersey
Not that this is a whole lot of help, but i did Moroso front springs on my third gen, i cut out 1 coil to get it to sit how i wanted it. They definitely helped with weight transfer. My advice would be to put the in as is and knock off 1/4 coil at a time until you achieve desired ride height.
DopeSick78
New Member
Feb 29, 2020
4
4
3
50
Sounds like a plan! thanks for the starting point. !
  • Like
Reactions: r_d_3
Dr.Exhaust
Member
Mar 31, 2020
8
3
3
41
Flint, Michigan
I decided to go with the QA1 front coil overs. Then you dont have to worry about cutting off to much and you dont have to R&R the springs 2-3 times. That was the biggest handling improvement ive made. Plus i can lift the front bumper 6 inches with one hand. Excellent wight transfer and higher speed in cornering. Ive got the QA1 rear pro kit now, just waiting for a new rear end swap before i start welding on the brackets. Cant wait to see the complete 180 on that.
  • Like
Reactions: r_d_3
unclepudge
348
CT
I am currently planning an LS swap and still have the factory V6 springs it's sits low with my 350 in it minor rubbing with 235/70/15's but it rolls alot in the corners curious how you make out as well. I have a GN rear in the back as well.
Dr.Exhaust
Member
Mar 31, 2020
8
3
3
41
Flint, Michigan
I have 205/70/15 in the front and 275/60/15 in the rear. I have also cut my inner fender wells in the front and removed the front sway bar. The factory rear sway bar is still on the car, but is accompanied by 4 UMI control arms. Pinion angle set at -1 degrees. Currently it has Comp Eng adjustable drag shock and air bags in Moog coils, and like i said QA1 coil overs in the front. I have removed all of the HVAC and emissions along with a few hundred pounds plus of unneeded weight. The front is currently set an inch lower in the rear. I love the feel of the car on a normal drive around town, and when that Mustang pulls up next to you at a stop light, its time to have fun. The QA1 stuff comes with a higher cost, but in my opinion, its well worth the price. And to answer your question, Ive never had a rub on any corner.
DopeSick78
New Member
Feb 29, 2020
4
4
3
50
So here is the results now. This pic is Moroso trick front springs, CE 90/10 shocks and 2001 2WD S10 spindles. No coils cut from springs. I am very happy with the stance and ride and suspension launches well.20200419_162856_1.jpg20200419_162856_1.jpg
G Moroso trick front springs Suspension Technical 2
D Front springs: V6 vs trick Suspension Technical 7
MISFITmalibu63 front trick springs Suspension Technical 11
grizwald trick front springs Suspension Technical 7
DFWMalibu Moroso trick 47130 front opinions.... Suspension Technical 5
A Moroso Front Trick Spring Rates? Suspension Technical 0
DOUG213XRJ Malibu El camino front air dam questions. General Discussion 5
T Best bang for the buck front suspension? Suspension Technical 5
B Front end travel limiters Suspension Technical 1
G Front Brakes Locking Up Wheels/Tires/Brakes Technical 3
orange87gp Front Sway bar improving 60 foot times Suspension Technical 3
T Bolt out front crossmember Suspension Technical 7
STROKER A body front control arms Suspension Technical 1
M front end help Suspension Technical 1
B Front drag race springs? Suspension Technical 1
U UMI Releases New Product: Front Frame Reinforcement Brace Suspension Technical 8
E Who are you using these days to rebuild the front end? Suspension Technical 3
H Front spindles interchange? Suspension Technical 8
L Malibu LEFT front headlight bezel Autobody/Paint Technical 2
7 Front fender? Autobody/Paint Technical 3
MISFITmalibu63 input on front swaybars Suspension Technical 1
7 Front coil overs in gbody cutlass..no travel..help!!! Suspension Technical 11
B Art Fiberglass front air dam Autobody/Paint Technical 0
t5montecarlo Sudden Continuous Screetching Sound at Left Front Wheel Wheels/Tires/Brakes Technical 5
bustedknuckles rebuild front suspension. Suspension Technical 10
B Tube front frame section Suspension Technical 5
2 Front to Rear Brake Line Assistance Wheels/Tires/Brakes Technical 5
B front brake upgrade question Wheels/Tires/Brakes Technical 34
S GlassTek or VFN Front and rear bumpers? Autobody/Paint Technical 0
S BMR or TRZ Front Control arms? Suspension Technical 15
B 78 cutlass front clip on 82 Autobody/Paint Technical 1
7 cutlass 442 front springs Suspension Technical 4
kevind Need some help picking a set of front springs. Suspension Technical 1
M 17x7 vs 17x8 front wheel Wheels/Tires/Brakes Technical 2
D 82 wagon front springs Suspension Technical 2
G 78 malibu front clip question Autobody/Paint Technical 1
7 Front suspension help Suspension Technical 2
nillabu UMI Front Coilovers Suspension Technical 9
W BBC MALIBU FRONT SPRINGS. Suspension Technical 1
R Front Springs Suspension Technical 0
D Lets talk suspension Please!! Moog 5596 front spring? Suspension Technical 6
kyhunter89 loosening front control arms and double nutting Suspension Technical 2
thumper Big Block front springs Suspension Technical 1
M front brake upgrade Wheels/Tires/Brakes Technical 1
M Spring rate for front afco coil over Suspension Technical 1
7 79 Front turn signal lamp Autobody/Paint Technical 1
lurchsmalibu 2012 Camaro 20X8 front rim on rear of 80 Malibu Wheels/Tires/Brakes Technical 3
1 Single or double adjustable front shocks? Suspension Technical 4
S Front end still shakes? Drivetrain Technical 4
S Front Clip Interchange? Autobody/Paint Technical 7
Similar threads
