Hey Guys,thought I'd throw in my 2 cents,seems to me that I used to test non functioning gas guages by grounding them to see if they'd do anything,good ground the guage would go to full,if it didn't the guage was bad,the fuel level sender is a potentiameter (big word I think I'm right) when the tank is empty there is little or no ground and when it's full it is a complete ground so I don't think Grand Lemans's problem is a lack of ground,I don't know for shure but I think our Pontiac cousins are wired the same way,I just went out to the garage and looked at my taillight harness and the red wire i believe is for the gas guage,look in your trunk on the drivers side and you should find a wiring harness coming over the wheel well toward the back,follow it toward the tail lights and you should find a plug,un plug it and then turn you ignition on and see what the gas guage does,if it goes to empty the guage and wiring to the back are good and you either have a bad sender or the wire after the plug going to the gas tank is pinched or bare and it shorting causing a full ground,if the guage stays at full either the guage is bad or the wire going from the plug to the dash is shorted somehow,Hope it helps! Good Luck,KillerDave
