I have been looking for a new engine for the el camino. Was looking at gm crate engines...
anyone have any experience with the circle track 350? looking to put into street car though. My friend works at local dealer so i get discount...any opinions on this engine?
Circle Track 350 Tech Specs:
Part Number: 88958602
Engine Type: Chevy small-block V8
Displacement (cu in): 350
Bore x stroke (in): 4.00 x 3.48
Block (P/N 10105123): Cast iron with 4-bolt main caps
Crankshaft (P/N 14088526): Nodular iron
Connecting rods (P/N 10108633): Powdered metal steel
Pistons (P/N 12514101): Hypereutectic aluminum
Camshaft type (P/N 24502476): Hydraulic flat tappet
Camshaft lift (in): .435 intake/.460 exhaust
Camshaft duration (@ .050 in): 212° intake/222° exhaust
Cylinder heads (P/N 12558060): Vortec iron; 64cc chambers
Valve size (in): 1.94 intake/1.50 exhaust
Compression ratio: 9.1:1
Rocker arms (P/N 10089648): Stamped steel
Rock arm ratio: 1.5:1
Recommended fuel: 92 octane
Maximum recommended rpm: 5500
