GM Head gasket Q
Got Torque
2,776
Stockholm, Sweden
Does GM's own .28" compressed thickness steel laminate head gasgets work with aluminum heads? I've got dished slugs and really need the narrow bore/thin gasket to keep compression up....
It's starting to look like the heads will be E-tec 170's.
If they won't work does anybody have something to recommend?
Goob
3,641
Indianapolis
Yup, they'll work.
I've used the #1094 Fel-Pro coated steel gaskets with aluminum heads too, no problems.
Got Torque
2,776
Stockholm, Sweden
Goob said:
Yup, they'll work.
Perfect! -I definetely trust your knowledge.
I better take a peek at those Fel-Pro's as well because they are even thinnner if my memory serves me right....?
Goob
3,641
Indianapolis
They are .015" compressed.
Damon
1,655
Philly Area
Used them several times with aluminum heads including the AFR-headed 383 in my Malibu currently. They work fine.
The 1094 Fel Pros are a coated steel shim (which is why they are thinner than the GM composition gaskets) and apparently also work real well, although I have never used them personally.
Goob
3,641
Indianapolis
I use them on everything that is a 4.0" bore base engine, won't work on 4.125" bore base engines.
Got Torque
2,776
Stockholm, Sweden
Good to know!
I beleive the .015 compressed thickness with the FelPro might be cutting it too tight since the shortblock is a 86and up piece that, if my memory serves me rigtht, doesn't have the slugs 0.025" down the holes like the older 350's used to have.
I need to double check that but my eyes tell me they are around .010-.015 down the holes.
I don't know how tight i dare to run but so far a .035 squish is the tightest i have used, and that was on a fully machined and meticoulusly built 383. -This is just a new-ish shortblock that will see some bolt-ons...
Goob
3,641
Indianapolis
The old standard O.E. replacement steel shim gaskets are .018" compressed.
I forget exactly what the Mr. Gasket steel shim gaskets squish to, but right in that area.....
