help to get car running
Easiest thing if you can't find one may be to just pick up an external 3½" drive.
http://www.bestbuy.com/site/olspage.jsp?skuId=6307436&type=product&id=1074787976171
That, or find someone with a 3½" drive (I happen to have one, but it's way up in MI in a parts bin) and a CD burner, they should be able to copy the files on the floppy to CD.
blue t
234
birmingham alabama
You should also put a check valve before the pump to keep fuel in the line it sound like the fuel is draining back to the tank. Is this a new build or did you have it running and now it doesnt? Have you checked to see that you have fire and check to see if the injectors are firing.
JP86SS
113
N.E. Ohio
www.wideopenwest.com
25# cranking sounds like the fuel pump is not getting the amps it needs when the starter is turning.
Check the ground paths and battery cables for good connections.
Might need a high torque starter if draws down that hard just to keep the voltage up for the fuel pump and ECM.
1QwikBu
1,387
olympia washington
email me your tune up and ill look at it to make sure everything is kosher [email protected]
for the guy looking for the old fast cd go here http://fuelairspark.com/Software/SoftwareRegistrationContent.aspx?prog=7 fill out the little questionnaire and download it .... everything thats on the cd is on there
