Anybody run one of these?
http://www.speedwaymotors.com/AFCO-Metric-Improved-Geometry-Centerlink,48370.html
I would try the centerlink along with the bump steer kit that Speedway offers. Their bumpsteer kit consists of two 5/8" heim joints that replace the outer tie-rods, two threaded adjuster tubes that replace your factory tie-rod adjusters and two adapter bolts that attach to the spindle that the 5/8" heims slide onto. However, I wouldn't use the adapters. When I ran that setup on my wagon, I still couldn't get the outer heims high enough to eliminate my bump steer. I ended up straight drilled my spindle knuckle to accept a long 5/8" bolt for the heim to attach to. Doing this gives you an extra 3/4" of upward adjustment on the outer tie-rod heim. I ended up with the heim all the way up against the spindle knuckle. After all was said and done, I had 3/16" bump steer. 1/8" toe-in at ride height and 5/16" at full extension.James Bond said:thanks for replies. i was looking for speedway's bumpsteer items and stumbled on the centerlink. my car now, with factory front end parts, sits about 1/2" off the lca bumpstop. at full droop, about 7" down, i see several inches of toe in. my car holds the front end in full droop for while after launching and it looks real nasty.
