Info needed on a Gbody frt brake up-grades
Stg1Regal
50
Eastern ,IN
I remember reading here or on one of the other forums, about upgrading the front brakes on a G-body .
I was about keeping your current spindles, and machining down an old brake rotor to adapt/fit a Covette rotor over it, or something like that.
It was also required to cut something off the spindles to fit a bracket for the correct caliper to mount
Sounds familar? I believe there was maybe a thread or link to one on this conversion.
TIA
Stg1Regal
50
Eastern ,IN
I found those links..whewww!!!
For the front brakes......
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/172762-ls1-brake-mod.html?referrerid=1864
And for the rear brakes...
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/206369-ls1-f-body-rear-brake-swap.html?referrerid=1864
