Is it worth the time to degree a cam?
attngtr
364
Eastern Iowa
I have installed cams before and just lined the dots up with no problems. Is it worth the time to degree a cam? I am going to install a .600 lift roller cam in my sbc and am curious if I should degree it this time. What are the benefits?
Thanks
attngtr
364
Eastern Iowa
Why? Is there alot more power to be gained in degreeing a cam?
wagonmaster
72
Green Bay, WI
Yes it is worth doing. Is there more power there if its done? Maybe. Maybe not. It all depends on if there are any errors built it to the cam timing pin, crankshaft key, timing chain key and locating hole, etc. You are basically checking for errors in these parts. If there are none you probably wouldn't have noticed anything. Its not uncommon to find 2, 3 or 4 degrees of error. How would this affect you is retarded cam timing may give you a little less bottom end or the opposite for advanced timing. Quality components help but don't eliminate the error posibility.
Damon
1,655
Philly Area
If the cam happens to drop in dead-on spec, there is zero to be gained. Most of the time (95%) they drop in +-2*. Nothing you'll ever notice on the street or, frankly, at the strip with most combos. But there are those times when something is really out of whack that you'll be glad you caught before you fire the motor up the first time. I've found a timing chain with the dot on the top gear off by ONE FULL TOOTH. And I've also found some cams that call for an intake centerline that is NOT already ground into the cam (usually shows retarded from cam card spec by about 4-5* when that's the case).
So, the vast majority of times it's not going to be a problem. But do you want to take the chance? It doesn't take long to check at least the #1 intake lobe centerline (point of max lift in most cases) against the cam card spec. Maybe an hour to do it, being reasonably careful (assuming the motor is on a stand with the heads off already).
Couple years ago I figured out a frustrating problem with a freinds motor that pulled like a beast down low but just didn't have the Wheaties up top. 2 YEARS of trying different bolt-on parts couldn't fix it. A quick degree operation on the cam showed the ICL was off by about 4* from spec AND THE LIFT WAS NOWHERE CLOSE TO CAM SPEC. Whoever built the motor simply shoved in the wrong cam- simple as that. We installed the RIGHT cam and the car dropped 8 TENTHS on it's next run at the strip. You can imagine the level of frustration that existed prior to finding out about this! It can happen to you, too.
Truckedup
64
Western NY state
It's always worth checking just to be sure.Like Damon says,a degree or two won't turn a good engine into a pig or turn a pig into a screamer.Generally speaking,a two degree error will move the torque peak up or down a few hundred rpm's depending on which way the error is.
Mike Allred
219
Fayetteville, NC
Another benefit of cam degreeing is establishing the true TDC of #1 piston. Find it and using an adjustable pointer permits you to set ignition timing exactly. Timing is just another "guesstimate" without finding true TDC on #1. Minimizing the number of educated guesses can be worth 25+ horses in most cases. Sweat the details!
